I have a 3620 lb 76 Camaro/350 030 over,I/SA 5:13 gears.9x30in tire
Cam specs intake exhaust .391 .411 duration 281 290 valve timing @ .050 int 25 btdc 49 exh 64 btdc 20 with 102.0 intake center line duratio @ .050 intake 254 exh 264 Please if you can recomend a mfg and stall I tested my car with the 4:56 and tci 8 inc converter and only ran 13.64 @ 97 mph the car would only stall to about 3000, I have now installed 5:13 gears and I am having a shop loosen the converter. Thank You for all your help I just want to qualify. |
The stall needs to be well over 5000, but how you get there is important too.
PM me if you'd like a specific recommendation. Need to know where you live .
You should get more mph with that combo, even if the convertor is too tight . Is that an up to date brand name stocker cam? ...Thanx Trevor
Liked 759 Times in 379 Posts
Call ATI and speak to Charlie Plott
Call Lenny at Ultimate Converter Concepts. His stuff is all I will run in my Stocker and my bracket cars. He is also a site sponsor, and a great guy to deal with.
Family Tradition Racing |
Liked 1,874 Times in 422 Posts
Call Tim Cole or Chris Padgitt at Comp to see if it is up to date.
I'd look at a 5.38 gear. The converter should probably flash closer to 5000-5500.
Alan Roehrich 212A G/S |
Liked 5 Times in 3 Posts
2nd the call to ATI.....5.13 gear is fine as long as you have a 2.75 low gear in the trans. ( a 2.91 metric would be better but..)
Liked 13 Times in 7 Posts
Don't confuse what stall you can reach on the brakes with flash stall. A 5000 or plus converter will only stall about 3000 on the brakes. Have a name brand converter mfg. modify the converter based on your specs. The mfg. will get it right at the start.
Richard Grant 4988 STK |
