Liked 419 Times in 85 Posts
1997 PMR Pontiac Ram Air Firebird SS/HA SS/IA SS/JA
This car was built by PMR Race Cars and is a great working car. This car will hook at any track. Car is a multi class winner, record holder and event finalist. Everything in and out of car has been up dated and very well maintained. Car is very light and is one of very few F Body cars able to make it to minimum SS/HA weight at 2820 lbs with driver. It would cost $100,000 plus to duplicate this car. Car has few passes and is not a used up vehicle like may others you may be looking at. Car was built to be modified car and was kept within limits to be legal natural super stock car. • Engine is 350 LT-1 285 HP factored at 279hp engine fresh 5/1/11 At that time heads were new from Gary Hettler Car is capable of going in excess of 1 second under current index Davis headers with merge collectors. • Aluminum Motor Plate & Mid Plate • 1-piece Removable Transmission Tunnel • Custom Weight box • Multiple weight bars & locations • 2 – new optima batteries as of 5/1/11 • 3 Gallon Aluminum Fuel Cell • Product Engineering fuel system with XRP light weight hoses Pump & Filter Combo w/ Regulator Holley DFI Hogan Intake Manifold • Mark Williams Axles – 40 Spline • Mark Williams Center Section / 5.67 Gears with Lamb Support • Mark Williams Aluminum Driveshaft • Mickey Thompson Front & Rear Tires Radial and Bias ply rear tires and wheels included. • V300 Racepak Data Logger • Lamb Components Front & Rear Brakes w/ Lamb Master Cylinder • Lamb Components Front Struts & Rear Shocks • ATI Converter • Scott Mclay 200 transmission with brake • ARC Control Panel • Kirkey Aluminum Drag Racing Seats • Precision Performance Products Air Shifter w/ ACD shift controller • Auto Meter Gauges • Custom Upholstery: door Panels, seat covers, carpet $57,000 Call Paul (702) 281-8520 Last edited by Paul Wong; 06-28-2011 at 04:27 PM. Reason: more information |
