Old 06-15-2011, 06:12 PM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Honing tank and Sunnen hone
Custom built honing tank for hand honing. Tank measures 36x30x24 and is on adjustable legs. It has a rack built into the bottom to mount the block through the main caps and rotate from side to side. It has a recirculating sump pump for fluid circulation. The tank sits far enough off the floor to allow the legs of an engine hoist to move under it, but not so high that it is uncomfortable to use. It has a custom wooden top so that it can be used as a table when not in use. Drain is the center bottom.
Sunnen AN-110 hand hone in good condition. Several sets of stones from 100 grit to 600 grit.
$250 for the tank, you arrange for pick up.
$200 for the hone and stones, you pay shipping.
