Old 06-09-2011, 12:50 PM   #1
tracyjw
Default Stock class transmission case breakage
Recently, I have received a large amount of concern over automatic transmission case breakage and safety concerns. I am interested in finding out how much a problem this is in the stock class. Your comments are greatly appreciated.
Tracy Winters
tracyjw is offline   Reply With Quote
Old 06-09-2011, 12:52 PM   #2
Liked 1,874 Times in 422 Posts
Default Re: Stock class transmission case breakage
Not a problem for us. However, we already approached NHRA, they are unwilling to accept aftermarket cases in Stock Eliminator. Well, at least for the automatic transmission cars.
Old 06-09-2011, 12:58 PM   #3
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
The only time I have encountered trans case breakage was due to chassis flex. With a properly installed roll cage and proper bracing there should not be any case breakage. Solid motor mounts, rubber trans mount and no chassis flex should eliminated breadage.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 06-09-2011, 01:01 PM   #4
Ron Middleton
Liked 12 Times in 4 Posts
I recently had this problem with the TH350 in my stocker. We never could figure out why the case broke like it did, but I called Wesley (Div. 4 tech man) and was told that OEM case only. It seems as though NHRA would rather leave it alone or move Stock into Superstock rather than allowing more superceded parts like trans cases.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
Old 06-09-2011, 01:01 PM   #5
Jim Kaekel
Liked 535 Times in 110 Posts
I've broken just one case in 30 years of racing and that was related to a U-joint failure....knock on wood!
Jim Kaekel 3836 STK
Old 06-09-2011, 01:01 PM   #6
Chris1529
Liked 70 Times in 29 Posts
I agree. I think using the wrong type of mount would cause our cars the most trouble. On a related note, do the JW bellhousings with the 30.1 flex plate sheild rating require indexing?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 06-09-2011, 01:05 PM   #7
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Stock class transmission case breakage
So NOW the NHRA does not want to allow better parts. It like closing the barn door after the cows have all left the farm !
Old 06-09-2011, 01:09 PM   #8
tracyjw
The bellhousing is SFI certified 30.1 for the flexplate shield and it fits onto the stock transmission case. You do not have to use an aftermarket transmission case. If I am correct the flexplate shield is required for vehicles running 10.90 or faster. I am not sure that I understand the question regarding the indexing? Let me know how I can assist you further.
Old 06-09-2011, 01:33 PM   #9
Chris1529
Tracy- PM Sent
Old 06-09-2011, 01:39 PM   #10
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
We index them. Have seen them off as far as .035". I'd rather be safe than sorry. $0.02
Larry
Larry Curtis is offline   Reply With Quote
