I wanted to get some feed back on whats the battery charger everyone is using? Im charging a bracket car with 2 batteries. Thanks Mike
Liked 5 Times in 3 Posts
I have a Craftsman (stand up on wheels) that I use it has a 40 amp setting & also a 200amp jump start if your in a pinch.
Liked 13 Times in 7 Posts
Use a digital Craftsman if you can afford it. One of the best purchases I ever made. It will tell you exactly how much you have charged your batteries. Charge to the max volts if you have time. Make sure that you can reach the same voltage everytime. It will make your car more consistent. Without a digital guage you don't know if you are reaching the correct voltage or not.
Richard Grant 4988 STK |
Richard i looked on Sears website , are you referring to the battery charger thats called the microprocessor ?
That's the one. Expensive isn't it? It's worth it though. I have had mine about 10 years. I've used mine to charge the boat battery, the scooter battery, the golf cart batteries, the trailer batteries, etc. It will sometimes shock a old battery back into service by placing it on high until it takes a charge.
Liked 69 Times in 32 Posts
I use a Schumacher speed charger, they are well built and show state of charge %
and charging volts plus have a setting for gel cell and agm batteries as well as conventional types. Approx 100.00 here
Ron Mattson 5015 STK |
#7 | |
Liked 3 Times in 1 Post
Wade O |
Don't know if it's the best, but we're using an XS Power "Intelli-charger". Charges both 12V and 16V AGM IntelliCharger compatible with 5A, 15A, and 25A(25A max) output. Three charging modes and LED indicators with ammeter to monitor status (grabbed that off of their site). It's part number 1005 if you want to look into it yourself.
Phil Hudlow 6678 (S/C, S/G, ET-PRO) |
Liked 4 Times in 2 Posts
I have a Black & Decker 25A-10A-2A Smart Charger. Have had zero problems with it. Also keep a 0.75A maintainer on it during the week.
Also, the Black & Decker unit will pop up error codes if there is a short in the battery or there are other problems. Another thing I really like about it is that if you hook it up backwards it will not charge and the lead is not hot until it knows it is hooked to a battery correctly and you set the charger.
Lee Norton - N229 STK IHRA H/FIA - NHRA O/SA RacerTees.com |
By far it has to be my old Snap-On charger. I'm at work so I don't have the model number. It's been ran over twice by a 4000lbs super stock car. And smashed another time by a 6800lbs Ford F350 dually. My god is it ugly, but yes it still works!!!
