1972 Nova Street Strip Buildup
$11,000.00 cash OR $9,000.00 cash & a SBC w/ 350 TURBO (for a street rod) -Front Suspension- Stock OEM Sub-Frame OEM Control Arms AFCO Low friction upper and lower ball joints AFCO Low friction bushings Moroso Trick coil springs (uncut) Lakewood 90/10 (QA1 Stocker Star R Drag Shocks New in box) OEM manual steering gear box Wilwood Disc brakes -Rear Suspension- 9" large tube and ends w/ backbrace "N" case Summers Brothers custom scolleped 35 spline spool Moser 35 spline axles 4.57 ring n pinion 1350 U-joints Calvert split mono leaf springs Caltracs Rancho X9000 9 way adjustable shocks mounted inboard AFCO leaf spring sliders Anti roll bar Large Ford drum brakes -Body and Chassis- Fiberglass front bumper Fiberglass 4" cowl Harwood bolt on hood Steel body New carpet w/ backing removed Steel rear bumper Jaz poly seats (2) RJS 5 point harnesses OEM rear seat w/ modified frame to clear mini tubs 10 point roll cage with swing out door bars CE weld in frame connectors w/ leaf spring pockets Rear mini tubs Tires and Wheels- Front Weld Draglite 15x4 w/ 2 1/4" backspace Front Tires MT 15x29x7.6 Rear Weld Draglite 15x10 w/ 51/2" backspace screwed Rear MT 30x9 ET Drag Radial Slicks -Tranmission- Hutch built Glide w/ 1.76 1st. gear w/ pro brake ATI 8" 4500 stall converter B&M Pro Stick B&M large cooler 31/2" Aluminum driveshaft w/ 1350 u-joints -Fuel System- 16 gallon Jaz poly fuel cell Jegs -10 in-line billet fuel filter Aeromotive Street/Strip 150 ghp fuel pump -8 fuel line Aeromotive Universal Bypass regulator -Current Power Plant- 460 cubic inch BBC TRW 43 cc dome pistons GM steel rods w/ ARP bolts GM steel crank .010/.010 Scotty Brown custom solid camshaft .636/.595 256/266 @.050 ICL 108 Solid lifters w/ EDM oiling Milodon 8qt. oil pan kit TCI balancer 063 Closed Chamber heads 101 cc w/ small valves Valve springs matched to cam Comp cams stainless roller rockers w/ poly locks Fabricated valve covers Team G 4150 intake uncut Proform 850 race carb MSD Billet Distributor w/ bronze gear 2" primary tube Hooker headers 3" "X" flow exhaust system into 31/2" Borla XR1 stainless mufflers Current weight 3,471 lbs Contact information day prowe@tweddle.com nite gearjammer@wowway.com 248-219-3118 please leave a message if I can't answer and I WILL return your call aas soon as possible Thanks for looking http://i49.photobucket.com/albums/f2...072Nova008.jpg http://i49.photobucket.com/albums/f2...072Nova006.jpg http://i49.photobucket.com/albums/f2...1014000940.jpg http://i49.photobucket.com/albums/f2..._p5RKV-M-2.jpg http://i49.photobucket.com/albums/f2...ngine001-1.jpg http://i49.photobucket.com/albums/f2...43_shNe8-L.jpg
Phil JPR Motorsports 1972 Nova Street Strip Project Last edited by gearjammer; 06-01-2011 at 12:11 PM. |
