Old 05-18-2011, 09:51 PM   #1
Bernie Cunningham
Liked 52 Times in 17 Posts
Default '98 Firebird LT1 Stocker / SS
Car is a '99 model year with a flat hood that puts in in C, D, and E, or SS/JA - SS/KA. Change to a ram air hood and it fits A, B, C, D, and E. A very versitle combination when Class is not been run. Custom ballast weights. It's factory dark blue with tan cloth interior, looks really nice!
Bud Rowe motor
Hedman headers
MSD HSV coil and wires
MSD distributor
Holley carank trigger
Complete Areomotive fuel system ( A1000 pump and reg.) and nylon braided hoses
CSR waterpump with spare
VDO playback tach
Holley Annilator ignition with a spare unit
Holley 950 Commander ECU with data logging and New O2
Moroso circuit breaker switch panel
Strong, switchable one wire altenator
T-action shifter
Munsinger convertor
Leo Glassbrenner (Remac) 200 trans, auto 1-2, deep alum pan
Has a E-shift installed but not currently used
Fuel cell and rear Optima battery, weight box
Strange rear wwith special alum drum brakes, new 4.88 gears
Lamb front brakes, S10 master with protected rod!
S&W rear anti roll bar
S&W chromemoly, tubular rear control arms
QA1 alum. shocks front and rear
Centerline Convo Pro wheels
M/T radials and front runners
Aftermarket steering rack
Almost new custom black carpet with foam filled floor
Rollbar with swing out side bar
Recently the car was stripped to nothing and put back together that included: the painting of the entire engine compartment and the under carraige with gloss black, re- engineer all brackets and plumbing, complete color coded re-wiring from front to back with all soldered joints using weather-pak connectors plus much more to make it a really neat package.
Located in Riverside Ca. call Bernie 951 686 4230 if your serious for pics.
$28500.00
Bernie Cunningham 7053 STK
Bernie Cunningham is offline   Reply With Quote
