Old 05-18-2011, 09:58 AM   #1
MRT
Default 700 CI 11 Degree 2-Stage Motor
700 cubic inch nitrous motor
Aluminum Donovan 11.625" Block 4.84 bore spacing
11 degree Dart Heads
2 stages Speedtech Nitrous foggers one hard line, one soft line
Speedtech Fuel system one regulator for carbs and nitrous systems.
Speedtech plumbed fuel system
T&D shaft rockers
Jesel Belt Drive
GRP Aluminum Rods
CP Nitrous Pistons
Comp Camshaft
Moroso Dry Sump pump
Brand New Stef Oil Pan
Hogans Sheet Metal intake
APD 1150 Carbs
Front Mount MSD Distributor
MSD Crank Trigger
Moroso Vac Pump
Comp .904 lifters
This motor was originaly built by Dave Slatten of Ft. Collins, CO (www.slattenracingengines.com). It has approximatly 40 runs since complete rebuild. New rods, pistons, valves, springs, lifters. Only sprayed both systems once and ran 6.97 at 197 in a #2500 door car with a very conservative tune-up. It dynoed 1300 on Slatten's dyno and is set up for lots of nitrous. Also have (2) spare pistons and a set of push rods that come with the motor.
See RacingJunk ad #2154363
Price is $21,000 and will split delivery cost to ship.
This motor has been well maintained and cared for. Please call with any questions. Thank You
Max Tafoya Jr.
505-280-7467
MRT is offline   Reply With Quote
