Old 05-18-2011, 08:46 AM   #1
sinistri
sinistri's Avatar
Default Alternator Mounting ??
Hey guys, im trying to mount an alternator on a 69 camaro w/ a small block. I would love to mount this low as to clean up the top of the engine. Im using a cs series delphi alt. And the low mount brackets i have do not allow frame clearance on driver or pass side. Im sure ive seen this done but cant come up with what brackets will work. The ultra mini alts dont really give more clearance because of the depth around 5 inch... anyone have a clue ?? thanks !! Roger
sinistri is offline   Reply With Quote
Old 05-18-2011, 10:32 AM   #2
novassdude
Liked 136 Times in 49 Posts
Default Re: Alternator Mounting ??
I use the low mount on my Nova (same frame) I had to make a couple of spacers and move the bracket out about 3/4 inch. I also reclocked the alternator to help clear the charging stud.
novassdude is offline   Reply With Quote
Old 05-18-2011, 10:41 AM   #3
Dragsinger
Liked 99 Times in 60 Posts
Novassdude,
send me your email address in a PM, I have some photos that might help.
Larry Woodfin
Larry Woodfin 471W
Old 05-18-2011, 10:44 AM   #4
Jim Kaekel
Liked 535 Times in 110 Posts
Check the Powermaster web site. This should help you out.
Jim Kaekel 3836 STK
Old 05-18-2011, 10:44 AM   #5
Dragsinger
OOOPS, I mean Roger send your email in a PM, my bad.
Larry Woodfin 471W
Old 05-18-2011, 11:18 AM   #6
skooter
Roger try Alan Grove.
Mid mount #235R might work.
Here it is with a CS130, you can modify the wp tubes for different type pumps.
skooter is offline   Reply With Quote
Old 05-18-2011, 11:23 AM   #7
Ed Wright
Ed Wright's Avatar
I used a nice billet street rod piece from Jegs to mount a stock alternator.
Ed Wright 4156 SS/JA
Old 05-18-2011, 12:56 PM   #8
FrankM
FrankM's Avatar
Liked 3 Times in 2 Posts
Check out part # 981 at the bottom, sounds like what you are looking for.
FrankM is offline   Reply With Quote
Old 05-18-2011, 03:43 PM   #9
sinistri
sinistri's Avatar
Thank you guys for the help ! Ive got a bracket assembly coming that should fix me up. I appreciate the input !
Old 05-18-2011, 03:53 PM   #10
Eddies66
Eddies66's Avatar
Liked 881 Times in 452 Posts
Low mount alternator bracket
SKU: 102174 Part No: 1000
$57.95
Modern Performance Classics
1-800-457-NOVA
Talk to Rudy
Eddies66 is offline   Reply With Quote
