Old 05-12-2011, 08:12 PM   #1
Shawn Pinkerton
Default Nova Chassis Car Turnkey
1978 TUBE CHASSIS NOVA
BAD MAN RACING ENGINES (MARK COOK)
406 SMALL BLOCK
EAGLE CRANK
WISECO 14.1 COMPRESSION PISTONS
TOTAL SEAL RINGS
DART PRO 1 HEAS 235 CNC
HARLAND SHARP ROLLER ROCKERS
CRANE ROLLER LIFTERS
HOLLEY STRIP DOMINATOR INTAKE
1000 CFM 4150 ALKY PRO SYSTEMS CARB
MSD 7AL2 W/STEP
MSD HVC2 COIL
MSD DISTRIBUTOR
MOROSO 10MM WIRES
CUSTOM MADE HOOKER HEADERS
W/ DYNATECH MUFFLERS
ABRUZZI GLIDE WITH CONVERTER
ELECTRIC BIONDO SHIFTER
WITH ADJUSTABLE SHIFT BOX
MAGNAFUEL 500 PUMP
-10 ALL THE WAY UP
9INCH REAREND
MOSER AXLES AND SPOOL
456 PRO GEAR
4 WHEEL DISC BRAKES
32X14X15 REAR TIRES
26X4.5X15 FRONTS
THIS CAR IS COMPLETELY REDONE FRONT TO BACK WIRING, PLUMBING, WINDOWS, INTERIOR, MOTOR, TRANS. EVERYTHING HAS 17 PASSES ON IT.
CAR IS A GREAT CLASS CAR AND BRACKET CAR JUST LOOKING TO TAKE SOMETIME OFF POSSIBLY INTERESTED IN A NAME BRAND DRAGSTER WITH 24.5 OR BIGGER CAGE. CAR HAS WON A TON OF RACES
CAR HAS BEEN 5.92 @116.5 MPH
WITH THIS NEW SET UP
Call Ryon
Phone Number: (440) 865-8788
Shawn Pinkerton is offline   Reply With Quote
