Old 04-22-2011, 10:01 AM   #1
jmcarter
jmcarter's Avatar
Liked 3,204 Times in 977 Posts
Default Small Block Mopar Race Parts
Doesn't look like I'll get back to this combination so here goes...
ALL ITEMS SOLD ...THANKS
1) Diamond Racing Enterprises W2 square port heads with matching Holley Strip Dominator intake (single 4150). These are one of the remaining Glidden sets. They need new valves and freshening. Flow sheet included (333CFM at .700, not bad for 70's technology but we are talking Glidden Pro Stock here). 5/02 update..just got back from the machine shop and the heads checked out as structurally sound. A few hairline cracks from plug holes which is very common on this type of head. $1600
2) Crankshaft Specialists 3.75 crank. .010/.010. One throw repaired by Crankshaft Specialists after I broke a rod. $500
3) Norris stainless roller rocker set for W2 heads (including shafts). 1.5/1.6 RR. $600
4) 904 with low gear set and complete freshen by Northwest TF guru Pat Blais. Turbo Action valve body, none of the light goodies but excellent bracket or backup piece. $500
PM or call for info/pictures Local reputable local machine shop assessed the heads and I have their information and you can call them directly if you'd like.
jimcarter340@gmail.com or cell is 912-401-4447
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-22-2011, 11:30 AM   #2
Phillip marvetz
Phillip marvetz's Avatar
Default Re: Small Block Mopar Race Parts
I'm interested in the 904 if you will be out here this summer.
2009 V/SA Record Holder
Old 04-22-2011, 12:08 PM   #3
jmcarter
jmcarter's Avatar
I should be Phil but not sure exactly when....grandkids duty and all.
I'll let you know on that...
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
