Liked 10,969 Times in 2,261 Posts
Fezell's 1.26 under at Charlotte Saturday should result in a 20 hp increase come Tuesday. That is 449 Hp. X 4.25% = 19.0825 Hp. then rounded to 20 Hp. = 469Hp.
The shipping weight of the car is 3240 devided by 469 = 6.91 lbs.per factored Hp. AA/S is 7.5 - 7.99 Is the car Super Stock only? |
#2 | |
Chad Rhodes 2113 I/SA |
Liked 13 Times in 9 Posts
or can it still move "up" to AA?
I believe you are right Michael.
Art Leong 2095 SS |
Liked 136 Times in 49 Posts
I would assume it can move to AA until it hits the max allowable weight that can be added.
If its factor is 6.91, it could move "up" if the class was a 7lb class, but at 7.5lbs its more than a class away, if you consider .5 to be a class.
Liked 3 Times in 2 Posts
Chad, you are correct, IF they go by the precedent that was set with the race hemi, T-bolts and L-88/ZL-1 cars. My bet......ford and nhra will 'amend' the current rules so it can remain in ?stock?.
Arnold Greene IHRA/NHRA 2420 A/S, B/S |
You may just see a7lb class(if you know what i mean)
Danny Waters, Sr / 73 Duster "340" |
Liked 460 Times in 91 Posts
aaa/s ??????????
Bob Bender 144 O/SA 2010-2012 National Record Holder Last edited by Bob Bender; 04-17-2011 at 12:13 PM. |
unfortunately, as you know all too well, the way its supposed to be, sin't the way they do things any more
