Old 04-09-2011, 11:17 AM   #1
nmc8165
Question buick 350 head gaskets
I have been using felpro permatorque head gaskets on my 68 buick 350 motor and after some decking to correct some issues from past motor work the compression ratio rose from 10.5 to about 12.5 and have blown out a few head gaskets.I've been looking for better gaskets with no luck other than to go to a copper gasket that means ringing the cylinders .there are no mls gaskets available that I could find and the cost of having a set made seems to be not an option.If any body out there has any info on head gaskets for a buick 350 it would be greatly appreciated.
nmc8165 is offline   Reply With Quote
Old 04-09-2011, 11:46 AM   #2
GTX JOHN
Liked 2,487 Times in 698 Posts
Default Re: buick 350 head gaskets
Try Cometic if available......they have solved a lot of problems on our Mopars.
Old 04-09-2011, 12:00 PM   #3
Phillip marvetz
Phillip marvetz's Avatar
I have run the copper gaskets without the rings on several engines and never had a problem, My current 360 bracket engine is 12.5-1 and has been going strong for 4 season now this way.
2009 V/SA Record Holder
Old 04-09-2011, 06:26 PM   #4
nmc8165
I talked to cometic and they wanted $3400 to start a die to make the gasket. but they did have a copper for the buick . I might try the copper without the ringing and see how it works, thanks for the info
Old 04-09-2011, 09:46 PM   #5
rowdyboys31
TA performance 1-480-922-6807 sells both steel shim and copper head gaskets for a 350. Steel $95 set/ Copper $135 The steel are the factory design appox. .020 thick I believe, if you don't want more compression you can stack two. JKeihn3954
rowdyboys31 is offline   Reply With Quote
