Old 04-08-2011, 10:24 AM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Default I Need Some Assistance.
I'm having a couple of small gremlins pop up with my car.
1. Can anyone recomend a Good Race Battery (12 volt )
There are sooo many to choose from. Part # would help too.
I have the Red Optima in there now.
2. A Mini Starter, i only used my jegs mini for 1 season & it looks as if it's garbage now.
3. A good Battery Charger, not sure if mine is working properly.
4. Does anyone use a trickle charger in between races ?????
Thanks for any help....
Old 04-08-2011, 10:36 AM   #2
Charlie Yannetti
Liked 192 Times in 83 Posts
Default Re: I Need Some Assistance.
Gee Pete, I thought you had gremlins.. LOL.. give East Coast Auto Electric a jingle.. they got all your stuff..
Charlie Yannetti is offline   Reply With Quote
Old 04-08-2011, 11:30 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,940 Times in 584 Posts
I use a red top Optima battery with good results
The black and decker electronic battery charger from Walmart is around $100 charges 40 amps and works great.
Starters dont last real long with locked timing. Do you use a starter saver or a retard to kill some timing while starting.
No trickle charger used between races. The Optima holds a charge really well. they are also paying contingency this year.
Mike Pearson 2485 SS
Old 04-08-2011, 12:00 PM   #4
BlueOval Ralph
Banned
Have starter spinning before you turn the ign on it will help save starter
BlueOval Ralph is offline   Reply With Quote
Old 04-08-2011, 03:20 PM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
To add to Ralph's if when you are spinning and flip on ign& and it starts kicking back,stop,start spinning again,except open throttle about 1/3 of the way and then flip ign. on and usaully they will fire w/o kick back.
On starters I've had good luck w/hitachi mini starters.I think they have 3 different outputs to choose from.There is alot of China starters out there that have plastic parts that should'nt be made,I've seen some that have plastic fork that goes from soleniod to drive,how could that even work the first time?
Mike Taylor 3601
Old 04-08-2011, 05:27 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
A 305 Stocker should not be eating starters or having any problem starting.
I had a brand new Jeg's starter giving me problems. I thought at first it was engagement issues and tried changing shims, still no good....The drive was N/G....it was slipping. If you lay under the car and use a remote button you can see what is actually happening when you crank it....
This is on a 509 15 -1 BB that was on gas at the time. I replaced the drive and it is working fine.
I also have used nothing but red top Optimas for well over 10 years with an alternator in 3 cars....Including my LT-1 Firebird Stocker a few years ago and had no problem.
Rich Biebel
S/C 1479
Stock 147R
Old 04-08-2011, 09:03 PM   #7
Dragsinger
Liked 99 Times in 60 Posts
this is a good between race dates maintainer;
http://batterytender.com/automotive/...-at-1-25a.html
This is a good at the races, between rounds charger on the 15 amp setting;
http://www.batterychargers.com/Produ...tName=94026499
And about batterys, a premium brand with high cranking amp rating should do a good job but you will get may answers on the subject.
The battery I am using just now is an A C Delco 78 - 7 YR Professional Series, very pleased with the performance.
Larry Woodfin 471W
Old 04-09-2011, 04:59 PM   #8
Pistol Pete
Thx everyone, i will put the information to good use.
