Old 04-07-2011, 05:00 PM   #1
Jamie Southards
Default Dedenbear TS6 Disc Style Throttle Stop
This has been sitting on the shelf for a while. We never used it because it would not clear the hood with our previous S/G setup. Is in great shape and comes with everything shown in the picture.
As advertised on Dedenbear site:
If you demand maximum horsepower, this is the stop for you. Mounted underneath a Dominator carburetor, it looks and acts like a 4 hole carb spacer. No restriction to flow at wide open means NO POWER LOSS! Exceptional repeatability when closed because air / fuel openings are in the center of the carb bore.
FEATURES:
* Designed specifically for the highest mile per hour cars.
* No flow restrictions for maximum horsepower.
* Needle bearings for smooth, precise activation.
* Centered openings for best repeatability.
* Simple and accurate adjustability.
* Corrosion resistant stainless steel and brass.
* Adjustable opening and closing rates.
* Low Profile - only 1.5 inches tall.
* Packages complete with solenoid valve, airlines and fittings.
$450 shipped
Please Call 540-454-0115
Jamie Southards
J219 F/GTJ
Jamie Southards is offline   Reply With Quote
