Old 04-02-2011, 10:31 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1966-70 BBC and SBC HI Performance Parts
1966 3873858 heads D-18-6 & E-2-6 rebuilt $2500
1966 3873858 heads F-13-6 & F-17-6 bare $1750
1967 3904391 heads J-10-6 bare $3000
1967 3904351 427 standard bore 4 bolt H-18-6 $6000
1968 3935440 396 4 bolt standard bore E-21-8 MQ coded camaro block $1250
1968 3935440 396 4 bolt 30 over F-10-8 CE warranty block $1500
1968 3919840 heads F-17-8 & F-18-8 rebuilt $1500
1969 3919840 heads J-31-8 bare $1250
1969 3919840 heads J-31-8 & K-4-8 bare $1100
1969 3919840 heads A-22-9 rebuilt $1750
1969 3919840 heads C-25-9 bare $1250
1968 3919842 single aluminum 6-15-67 (hairline crack) $750
1968 3919842 single aluminum 10-29-67 (milled) $750
1969 3919842 aluminum heads rebuilt 10-24-68 & 6-2-69 $3500
1969 3955272 L89 396 4 bolt J-7-8 with JJ code out of camaro 1 of 311 $3000
1969 3955272 L89 396 4 bolt J-14-8 with KG code out of chevelle 1 of 400 $3000
1970 3964291 single head D-23-70 bare $600
1969 3932472 302 Z28 aluminum intake $450
6223 steel crankshaft freshly turned 10 on mains 20 on rods $300
8 inch timing cover with teeth design timing tab $100
1966 #5271 396-375HP primary metering block $35
Holley Acutator and screws $15
All heads and blocks cleaned and magged. Can ship if you cannot pick up and can be reached at 330-770-2517 for any questions and have pictures of parts if needed.
dlv4540 is offline   Reply With Quote
