Old 03-30-2011, 11:49 AM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default TH350 Line Pressure
This ties into another thread discussing the use of a hydraulic pressure switch for the 2-step activation on the brake system.
Since you need a safety switch in the circuit to only activate the 2-Step in low gear I like the idea of putting another pressure switch in the transmission low gear pressure test port to act as the safety. I see from the TCI website that line pressures would be in the 145-175 psi range when in gear.
But my question is will there be any residual line pressure once the car is in 2nd or high gear or does the pressure on the low port drop all the way to 0 psi?
I think this would be a more robust solution over putting a micro switch on the shifter safe guard the 2-Step from coming on when you don't want it to.
Thanks,
Chad
Chad E532 is offline   Reply With Quote
