Old 03-27-2011, 08:25 PM   #1
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Default Traction issues
My truck is a ladder bar coil over set up with MT 29.5X11.5X15 slicks. My old tires gave up after a year and a half and I bought a new set, same size. The new ones don't seem to be sticking. My 60 fts have dropped from 1.42, 1.43 to 1.50 plus. I've got the ladder bars in the bottom hole and the shocks set soft, 3 and 4 clicks left to right. They are Varishocks single adjustable. Am I hitting the tires too hard or are the new ones not as good as the old ones? They just cost me a race when I let go of the button and they just blew away. Had to peddle and then couldn't catch the guy.
Any ideas?
Floyd Staggs 787 SST
Old 03-29-2011, 01:18 PM   #2
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Default Re: Traction issues
Not familiar with m/t, but have you checked to make sure that the compound is the same as your old tires? Have you tried them more than one race? Maybe the track prep wasn't up to par. Like that ever happens. lol
C and W Racing is offline   Reply With Quote
Old 03-30-2011, 11:17 AM   #3
Floyd Staggs
Yes, I tried them 2 weekends in a row, same track. Nobody else seemed to have any issues that I know of.
As far as I know that tire size comes in one compund only. This is my 3rd set of these and the first time I have had any issues.
Question, which hole hits the tire harder, bottom or top?
Old 03-30-2011, 02:50 PM   #4
C and W Racing
You said your old tires gave up. Were they doing the same thing as the new ones? On a ladder bar, you can't change the length of the bar, so technically, it hits the same, what you can change is the lift point, relative to the nuetral line. If your truck was mine, I would have the lower bar parallel to the ground or slightly pointing down. The best way to see how it is hitting the tire is have someone vidio the truck with a good look at the rear tire. If they use a digital camera and you can play it frame by frame, you can learn a lot. On the truck that I had, I ran the shocks full soft, with the long wheelbase that it had, it needed the help for pitch rotation. That truck would go down a dirt road and it would go red on a pro tree
Chuck
Old 03-31-2011, 10:39 AM   #5
Floyd Staggs
The old tires just wouldn't hook any more. They would spin at the hit, not as bad as the new ones.
My bars are in the bottom hole, slightly down, and the shocks are 2 clicks left, 4 clicks right from dead soft. I've got 150 lb springs on the back.
Would you like to come help me get mine sorted out? I sure as hell can't go red on a pro tree.
Old 03-31-2011, 10:43 AM   #6
Floyd Staggs
C & W, check this out.
http://www.youtube.com/watch?v...xt=1&list=QL&index=1
Old 03-31-2011, 02:34 PM   #7
GaryGoFast
Talking Re: Traction issues
Any chance you may have a spring or shock issue?
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
Old 03-31-2011, 04:05 PM   #8
Floyd Staggs
I could have issues but it was working good till I changed tires. No ther changes except for launch chip and tire pressure.
I'm taking the tires back to MT tomorrow and we will check the hardness. They were suprised when I told them they didn't get sticky after a burnout.
Old 03-31-2011, 05:31 PM   #9
C and W Racing
Put hoosiers with an 07 compound on your truck and it will fix your problem
Chuck
Old 03-31-2011, 06:12 PM   #10
Floyd Staggs
Now ya tell me after I paid MT $460.00 for theirs.
