Old 03-25-2011, 11:40 AM   #1
Glenn Betz
Default 2005 Pontiac Sunfire GT/AA-DA
2005 Pontiac Sunfire Super Stock/GT car. This car has a Strange 9inch Ford rear end, Strange aluminum center section with 5.67 gear and Strange axles and brakes, Full chrome-moly tubing chassis 4-link, Strange struts and brakes. It has Mickey Thompson wheels and front tires, Hoosier Radials tires, ATI Powerglide with ATI converter, The transmission has just been freshened up and the converter was new in June 2010 with about 30 runs on it. MSD 7-AL3 ignition box with MSD coil. The engine is a 350 small block 300hp. With this motor the car will run GT/AA and GT/BA. Car get down to 2710# with 160lbs driver.
Also, 350 small block 255hp engine built by David Haag Racing Engines. Has about 20 runs on the engine. Bowite block, Callies crank, Manley rods, BME pistons, Heads UP! Cylinder heads and Intake, Manley valve springs, Jesel rocker arms and belt drive, Manley valves, C-Line Box Oil Pan, Bullet 50MM camshaft and Crower .904 lifters. With this engine car will run GT/CA and GT/DA. Asking $15,000 OBO
Also, a 350 Chevrolet Bowtie #184 small block. Bore size is 4.056 and the deck height is 8.852. Has the .904 lifter bores and 50MM roller cam bearings. Had it pressured checked and everything was ok. Asking $1500 OBO
Spares, spare ATI converter, two spare camshafts, car cover and a Derby City front-end cover.
Car with 350/300HP engine - $35,000 OBO
Car with 350/255HP engine - $42,500 OBO
Car with everthing $50,000 OBO
Call Glenn Betz at (812-342-9408)
Glenn Betz is offline   Reply With Quote
