Old 03-19-2011, 04:59 PM   #1
Maverick
Liked 36 Times in 26 Posts
Default fuel cell foam
I am thinking about taking the foam out of my fuel cell. I really don't know if it will change anything, but wanting to know if other racers, run with or without cell foam. I have a 4 gal jaz cell, that is like the one they use in dragsters, with a number 10 pick up. Will I gain any capacity if I take it out? I believe they use it to keep the fuel from sloshing and if it is punctured, keep it from running out real fast. Thanks in advance
Old 03-20-2011, 09:25 PM   #2
THE LEGEND
Default Re: fuel cell foam
Mine is out
THE LEGEND is offline   Reply With Quote
Old 03-20-2011, 09:55 PM   #3
FED 387
Liked 333 Times in 180 Posts
take it out it will degrade over time a send small particles thru the fuel system and ultimately create clogs
Old 03-21-2011, 01:57 AM   #4
HR9121
HR9121's Avatar
Mine is out also but you need to keep your fuel cell topped off so you don’t get any sloshing. James
Old 03-21-2011, 10:59 AM   #5
Bill Baer
I too have a 4 gal Jaz dragster fuel cell and am using methanol for fuel and my foam is in and has been for ten years over which time I have removed instected it four times and have seen no signs of degradation others results with gasoline may be different.
Old 03-21-2011, 12:18 PM   #6
SCOTT SST2871
Mines out but it was in for 10 years with no problem on methanol
scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 03-21-2011, 01:57 PM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: fuel cell foam
Same here. Keep it topped off. Jim
