Old 03-03-2011, 01:11 AM   #1
jeffsracing
Default 550 cu in 900 HP BBC Engine
550 cu in Big Block Chevy Drag Racing Engine
Engine has dyno time only since built and made approximately 900 HP. Well built engine by a reputable engine builder with good internal parts and would be a great bracket or super category engine.
Built by Ultra Tech Racing Engines Mishawaka Indiania
Bowtie 4 bolt Block Casting 10051107
Cola Crank 4.25” stroke 4340 internally balanced
Oliver billet steel connecting rods
Dave Riolo of Riolo Racing Engines ported and matched Dart 320 Heads
1.625 springs
B & B oil Pan
Jesel Belt Drive
Crower Roller Rockers
Wiseco 4.540" Pistons 13.5:1
Total Seal piston rings
Dart intake with massaged runners and Dominator flange
Crower 318R Roller Cam
Intake duration 318 lift .757
Exhaust duration 326 lift .745
Stud Girdle
ARP Head studs
CSR flexplate
ATI Super Damper
Valve springs are backed off. Adjust valves, add carb and ignition and ready to go.
6800.00 dollars
402-432-6212
See link below for pics
http://www.racingjunk.com/category/9...BC-Engine.html
jeffsracing is offline   Reply With Quote
