Old 03-02-2011, 05:01 PM   #1
Randy Schonscheck
Liked 2 Times in 2 Posts
Talking Roller Rockers On A 300HP Chebbie Crate Motor
I was wondering what brand of 1.5 roller rockers that you guys have run on these heads. Just looking at the different styles, some seem larger in physical size, like a Comp cams , Crane etc compared to the Crower stainless steel which looks somewhat smaller. Will these rockers fit under the steel center bolt factory stock ones, with the shields and deflectors or do you need the GM Perf aluminum ones or other aftermarket ones? The GM ones are about 1/4 inch taller, I don't want the adjusting nuts or anythng to be hitting or rubbing. Thanks!
Randy Schonscheck is offline   Reply With Quote
Old 03-03-2011, 03:31 AM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: Roller Rockers On A 300HP Chebbie Crate Motor
Harland Sharp .....
Old 03-06-2011, 12:12 PM   #3
Phil Veldheer Racing
Liked 26 Times in 8 Posts
Default Re: Roller Rockers On A 300HP Chebbie Crate Motor
Harland sharp!!!!!!!!
PHIL VELDHEER 3455 STK
IHRA WORLD Record Holder
2007-08-09-10-11-12-13-14-15-16
Phil Veldheer Racing is offline   Reply With Quote
Old 03-06-2011, 03:12 PM   #4
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Talking Re: Roller Rockers On A 300HP Chebbie Crate Motor
The stock center bolt valve covers work fine.I cut one of the supports that go from the valve cover to the center bolt sleeve for some added clearance.I used the comp chrome moly rockers,but I think the harland sharp are cheaper.I used screw instuds and guide plates but will not the next time.I like the Harland sharp self aligning rockers with stock pressed in studs.Good luck
Kevin
Old 03-06-2011, 09:59 PM   #5
Randy Schonscheck
Thumbs up Re: Roller Rockers On A 300HP Chebbie Crate Motor
Thanks guys! I thought they would fit but wanted to tap into others'experiences with these heads. Phil, should I give Nick at Comp Products over in Oshkosh a call for these??? Randy
Old 03-07-2011, 09:04 PM   #6
Now THAT was funny....not everyone knows that I have there logos on all six race cars....get everything I can from them the next day....great company! Thanks and good luck.
Phil
