Old 02-27-2011, 09:49 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default SBF oil pump
anyone know a ford or aftermarket part number for the SBF oil pump relief spring cup? i've replaced the factory spring with a stiffer unit but can't find the proper sized cup that retaines it...
Old 02-27-2011, 11:50 PM   #2
west coast
Liked 227 Times in 74 Posts
Default Re: SBF oil pump
This is the pump I run did alot of research. Melling 10687 has a threaded plug for the relief spring it also has support on on both sides of the gears shaft. Nice pump compared to what else is out there got mine from summit for about $50.
west coast is offline   Reply With Quote
Old 02-28-2011, 08:17 AM   #3
BlueOval Ralph
Banned
Is it a gear pump or G Rotor?
BlueOval Ralph is offline   Reply With Quote
Old 02-28-2011, 08:41 AM   #4
richie 2
10/4 on the 10687 west coast. thankyou. (motor is a 302ci) i just have this mellings std. volume gear type pump new on the shelf and i'd like to move it...canton lists a higher pressure spring and the required type plug, they say it's a '69/'70 boss 302 plug. sometimes the simplest things turns into an aggravating situation....
Old 02-28-2011, 09:11 AM   #5
richie 2
part # C20Z6A616A... 21/32" OD...NLA from ford.
Old 02-28-2011, 11:57 AM   #6
west coast
Blueoval Ralph it is a gearotor pump this one is a standard volume they do also make them in high volume.
Old 03-09-2011, 03:26 PM   #7
richie 2
gearotor style...my mistake. 21/32" shallow plug found at the parts store. tapped gently to get the plug to start and snugged up the pickup tube & gasket into place. canton spring made 72lbs. pressure on the stand. (hyd. roller 302ci., street clearences w/shell 15/40 rotella T.)
Old 03-12-2011, 08:43 PM   #8
Steve Sullivan
Steve Sullivan's Avatar
Liked 29 Times in 14 Posts
Dorman makes a replacement part - #555061 You can get them at rockauto.com
Steve Sullivan is offline   Reply With Quote
