what intake is better for a 1968 396/375 nova/camaro a 3885069 or a 3933163
Liked 880 Times in 311 Posts
If it is legal... 19131359
Adger Smith (Former SS) |
The 359 is the legal replacement for the 163 intake. That's the one you want, in most cases. You may find the rare 163 that makes power, but odds are you'll go through 10 to do it.
Alan Roehrich 212A G/S |
Liked 136 Times in 49 Posts
From a quick search the 359 is still available new around $250 Most of the 163's I seen on e-bay were well above that. I would leave the 163's for the collectors and pick up a 359. especially if people say they make more power.
thanks guys
The biggest difference is in the way the fuel channels run in the bottom of the area under the carb. Better mixing of the fall out fuel with the air.
John, You have a PM
Liked 99 Times in 49 Posts
Adger how can you tell the the fuel dist is better, I have both intakes and have seem very little diff on the dyno. Jim Hanig just wondering.
Jim,
Are you using 8 EGT probes, one in each primary tube?
EGT's and plug readings & Tq and HP Last but not least BSFC
i have a 163 laying on the shelf if needed cheap.
