Old 02-20-2011, 10:22 AM   #1
L79racer
L79racer's Avatar
Default Converter multiplication ?
I was talking converters to a few guys and they said that I should have told ATI my converter was going in a super stock car as they do some thing different to the multiplication in the converter. Any thought on this? Also, said to check out ultimate converter. Anybody using them and any thoughts or opinions over ATI?
L79racer is offline   Reply With Quote
Old 02-20-2011, 11:34 AM   #2
Liked 1,853 Times in 419 Posts
Default Re: Converter multiplication ?
Yes, ATI has a new stator for Super Stock. And yes, you have to tell them the exact combination, fill the spec sheet out completely, and tell them what you're doing, so they can get the converter right. You cannot expect them to guess or read your mind and get it right.
Old 02-20-2011, 12:10 PM   #3
L79racer
L79racer's Avatar
I did have them set it up for my combo with all specs. I was told that they had a little different set up for super stock and was wondering if it would get a better 60'. I have a 5500 stall in it and I feel it doesnt leave hard at all. I am used to sticks thought. Here is the best pass so far.
Old 02-20-2011, 12:24 PM   #4
It looks soft, but without knowing more, it's hard to say why.
Old 02-20-2011, 03:22 PM   #5
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Converter multiplication ?
L79racer,
Talk to Lenny @ Ultimate Convertor , does a great job & his convertors really work .... You would be surprised at how many racers are using his stuff ... Lenny is also very easy to work with and very dependable .... Call him, you won't be Sorry ....
704-892-6837 .......
Dave Ribeiro 1033 STK
Old 02-20-2011, 10:44 PM   #6
Dragsinger
Liked 99 Times in 60 Posts
I also like Lennie at Ultimate. A good Guy doing a good job.
In the Video I see a 1.40 sixty foot on the board. For reference, my Firebird does a 1.37 sixty foot with a 9.70 ET so you are close.
Larry Woodfin 471W
Old 02-20-2011, 11:04 PM   #7
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Why, that ain't no super stock car.
That said, none better IMO than ATI!
Those that think they are, I invite them to step up
The PROOF IS IN THE PERFORMANCE
3124 lbs. n/a and a best to date of 1.17 60 foot launched off the footbrake.
Old 02-21-2011, 09:07 AM   #8
L79racer
L79racer's Avatar
Larry, are you running a glide? I have a glide and always felt the glide was hurting the 60' a little bit. That run was in great air. It usually will go low 10 teens to 10.0's with a 1.43 60' depending on the air.
Old 02-21-2011, 09:10 AM   #9
L79racer
L79racer's Avatar
yes I know its not a SS car but looking to get it to leave a little better. What ET and MPH are you running? Can you post some more specs on your car? I like ATI, no complaints, just curious of the info I was hearing.
Old 02-21-2011, 10:42 AM   #10
1320racer
1320racer's Avatar
If you have questions as to whether your current converter is optimum for your combo speak to Charlie Plott at ATI.
Be prepared to provide him with factual data, including but not limited to what does the converter flash to on launch, what RPM does it fall back to on the gear change(s) and what RPM is it crossing the stripe at and the only way you'll know this is with a playback tach or data logger.
As to my car's specs...
522 BBC, turbo400, 4.57 gear.
Slowed to run low 9.0's all season long at near 150
More importantly what are the specs of your car/combo?
