Old 02-13-2011, 11:15 PM   #1
BRIAN SEATE
Unhappy Holley fuel pressure regulator issue
I was flushing the lines on my Camaro when I noticed a fuel leak from the bottom of my new Holley big port regulator. The fitting came with the kit, everything was tight. I even used paste after trying first with teflon tape on the NPT coming in from the bottom. Never run into this with a regulator, was getting late called it a night. Could it be a cracked fitting or cracked regulator. Anybody ever had bad regulators or fittings out of the box? Gonna get a fitting Monday at the local speed shop and start there. Nothing was over tightened, put several on in the past. Thanks for any input.
BRIAN SEATE is offline   Reply With Quote
