Old 02-13-2011, 02:02 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1968 396 L78 Blocks and Parts
1968 396-375HP standard bore 4 bolt block casting number 3935440 dated E-21-8 with front pad stamped T0524MQ 18N449843. The block originally came out of a 4speed 1968 camaro. The block was cleaned, magged and pressure tested good and has two sleeves installed and are good $1250.
1968 396-375HP 30 over 4 bolt block casting number 3935440 dated F-10-8 with front pad stamped CE871320. The block is a factory warranty replacement block and has been cleaned, magged, pressure tested good with one sleeve installed and is good. The block has new cam bearings and freeze plugs installed as well $1500.
1968 3919840 square port heads rebuilt dated F-17-8 and F-18-8 with no porting and have stock size 2.19 intake and 1.72 exhaust $1500.
6223 steel crankshaft freshly turned 10 under on the mains and 20 under on the rods ready to go $300.
1968 3919842 aluminum heads dated 6-15-67 (hairline crack) and 10-29-67 (milled) $1500.
330-770-2517 and can send pictures if needed and can ship if you cannot pick any of the parts up.
dlv4540 is offline   Reply With Quote
