Old 02-09-2011, 12:21 AM   #1
et7333
et7333's Avatar
Default Chevy parts 4 sale
BRAND NEW, not rebuilt, mini starter, 3 h.p.,168 tooth - $185
IF YOU DON'T SEE WHAT YOU NEED HERE, I MIGHT BE ABLE TO GET IT. PLEASE, JUST LET ME KNOW WHAT YOU NEED. THANKS
8-JE NEW LOW TENSION 4.030X3/16 OIL RINGS ONLY- $25
Manley standard length super duty sbc valves, 8-2.055, 8-1.60 ground and ready to install. - $130
GM 1.6 STAINLESS pro flow ex valves NEW - $75
HELWIG HELPER SPRINGS LP2510 $80
Manley #22441 1.550 valve springs,brand new - $110
Moroso Nova oil pan,#20211 used - $75
MELLING M55HV billet gears oil pump NEW - $40
Moroso oil pump pick up #24360 New - $39
Several powerglide cores, make offer
Factory front drum brakes 68 camaro $60
NEW Comp Stamped Steel 1.5 Ratio 3/8 Stud part#1212-16 - $45
1.76 Hardened powerglide input shaft TURBO splines USED - $60
RJS 5 point Belts outdated - $25
1 SET 12 BOLT GM POSI CLUTCHS
Manley raised guide plates #42151-8 $12
ARP#134-7101 3/8 screw in studs $20
NOTE:
Prices do not include shipping. PLEASE contact Steve at et7333@netzero.net
http://stevecoxracing.com
et7333 is offline   Reply With Quote
