Old 02-07-2011, 10:57 PM   #1
RuggedRacing
RuggedRacing's Avatar
Default 87 monte ss
87 MONTE SS
This car has been updated by C&F race cars, it was purchased by me as a street car and I had all the work done to it, this car has not been threw any ones hands but mine, it has all the latest and great components in it. I have the title and registration for the car and car can easily be converted back to a street car. The car was painted only 2 years ago and looks brand new. I have every piece of documentation on the car from instructions to receipts. You will not find a nicer Monte SS out there. This is a super street/ bracket car. It runs 10.90 at 127 on the t-stop and 10.13 at 132 off the t-stop. This car is being sold turn key. Here are all the features:
CAR
·12 point 4130 chrome moly cage with 8.50 Cert
·Moser 9” Ford with heavy duty backbrace, 35 spline axles, 4:56 gears
·Jegs lift bars
·Jerry Bickel Anit-Roll set-up
·Custom driveshaft with strange yoke
·Competition Engineering 70/30 rear shocks
·Competition Engineering 90/10 front shocks
·Strange Heavy Duty front disc brakes
·Master Power master cylinder
·Light weight steering box
·Solid body mounts all around
·Energy Suspension poly engine and trans mounts
·5 gallon fuel cell
·MagnaFuel 280 fuel pump(just rebuilt by MagnaFuel) and fuel filter
·BG fuel regulator
·CSR electric water pump
·Electric cooling fan mounted on radiator
·Powermaster 110 amp Alternator
·Kirkey aluminum racing seat
·Aluminum glove box
·M&R safety belts
·M&R safety window net
·C&F custom removable dash
·Hurst Quarter Pro shifter with electric shifter solenoid
·Grant 3 spoke sport racing wheel
·Helmet hook
·Billet Specialties Street Light wheels
·Hoosier front tires 28x4.5x15
·Hoosier rear tires 28x10.5x15
·4” fiberglass cowl hood
·Tim Mcamis hood scoop
·Everything is steel except hood
ELECTRONIS
·The ignition system is new with only 2 races on it
·MSD 7AL2 plus igntion box
·MSD Pro Power Coil
·MSD noise filter
·MSD 3 step
·MSD Crank Trigger
·MSD Distributor
·Biondo Mega 450 delay box
·Autometer gauges
·New Autometer play-back monster tach
·Painless wiring switch panel
·2 Optima batteries
·Dedenbear under the carb butterfly electric t-stop
TRANSMISSION
Select Performance Powerglide Transmission
·Select Performance 8” Converter
·Dedenbear SFI Case
·1.76 gear
·Transbrake
·Transmission cooler
MOTOR
·JA Performance 406 SBC
·Chevy bow-tie block
·JE pistons
·Crower rods
·Callies crank
·Comp Cams camshaft
·Comp Cams roller lifters
·Comp Cams valve springs
·Manley push rods
·World Products angle plug heads
·Crane rockers
·Crane stud girdle
·Edelbrock intake
·Moroso oil pan & pickup
·ATI balancer
·B&B timing indicator
·Moroso valve covers
·Fel-Pro gaskets
·Hooker Headers-Nitro Plated
·Tilton Starter
New 950 HP Nickerson carb
EXTRAS
·Full set of winter wheels(weld prostar)
·Stock Headlights
·Stock front brake set-up
·2nd set of door panels
Complete Carpet for Floor
$20,000 complete NEG. just get in the car and go racing
Serious Inquiries Only
Call Ryan 516-807-0768 or
Email RuggedRacing1900@aol.com
RuggedRacing is offline   Reply With Quote
