Old 02-06-2011, 02:57 PM   #1
russellauto1
Liked 35 Times in 6 Posts
Default 1993 Stock or Super Stock Mustang
I have a 1993 mustang LX hatch back that I was setting up for Factory Stock. The car only has 48,000 miles on it. Has been a street strip car all of its life. Car is painted black underneath, Reinforced upper and lower torque boxes. Has a 10 pt cage that is mild steel and mig welded. Has through the floor frame ties also. Has complete interior with console. Dash is in Great shape. It is set up for a 5 speed with granatelli linkage. Has 2 Kirkey 17" race seats with new black covers. New Fuel tank with 255lph pump. Has trans loop, and New trans Crossmember installed. Master disconnect in trunk. The fire wall and all of the holes have been smoothed and are painted the same color as car. Has a new 1" Lowering springs all the way around. New Front Strange Struts and lakewood rears. Rear has Adjustable everything on it. Upper and lowers. The rear end has Moser 35 spline new axles with c clip eliminators, with Matching spool. Girdle on rear of housing and axle tubes welded. The car will need a little touch up on paint as there is some bubbles by Antenna, and Rear hatch. The rear rims are weld with Champion Beadlock rims on the Outer bead. They are really nice also. Has 5/8 4 lugs on rear. Rear drum brakes and factory front disc. It will need carpeted and the cage painted. It comes with a Lift off Fiberglass 6" cowl hood that is Zeus fastened. omes with a optima battery and hold down in rear of trunk. I really like the car and don't want to get rid of it, but my work tells me different. You could go several ways with car. If you wanted to change hood and seat you could go Stock eliminator racing. If you changed the hood, it could be a Super Stock Car. For other questions, Call 1-614-578-8658 and ask For Aaron. The price is 4500.00$ for a fast sale. Thanks For looking! I can Email pics to your Email.
russellauto1 is offline   Reply With Quote
