Old 02-01-2011, 08:37 PM   #1
racecarbob61
Default hemi 4 spd, t-10 4 spd, glide,convertor/12 bolt
PRO SHIFTED HEMI BOX--- .ALSO FITS CHEVY .GEAR RATIOS ARE APPROX 1st 2.90,2nd,2.20,3rd,1.70,4th 1-1.THE ONLY NUMBERS I FOUND ARE 2801176 ON L/S OF FRT CASE &C95664 ON SIDE COVER. I DONT KNOW TO MUCH ABOUT THIS TRANS IT CAME IN A PACKAGE DEAL OF PARTS I BOUGHT I WAS TOLD IT WAS DONE BY LIBERTY BACK IN THE LATE 80'S I HAVE SCATTER SHIELD AND ADAPTER FOR CHEVY WITH HURST RAM 4 INLINE SHIFTER, . $1500.00 or B.O.
BORG WARNER T10 4 SPD . CLEANING GARAGE. GOT THIS IN A PACKAGE DEAL. DATE CODES ARE -- TAIL HOUSING IS 7-20-62. MAIN CASE IS G-24-C2 COARSE INPUT SHAFT. SMALL OUTPUT SHAFT( TH350) COMES WITH HURST SUPER SHIFTER& SCATTERSHIELD WITH BLOCK PLATE (NO SHIFTER HANDLE) GEAR RATIOS ARE APPROX. 1st-2.20,2nd 1.70,3rd-1.20,4th-1.1-
$900.00 OBO
POWERGLIDE BUILT BY DYNAMIC HAS TURBO INPUT SHAFT,NO BRAKE STOCK CASE 1.76 GEAR, WAS IN STREET CAR FOR A MONTH BEFORE I SWITCHED TO TH400.. TRANS $450.00 2 CONVERTORS, 1 STALLED 4200 BEHIND 383 IN S-10 @3200lbs 6 MONTHS OLD $240.00 OBO. 1 STALLED 5500 BEHIND 468 IN MALIBU @3400lbs NEW 10 PASSES $450.00 OBO
1966 CHEVELLE 12 BOLT,5.38 GEARS,STRANGE SPOOL & ,AXLES,CUSTOM REAR BRACE,SPEEDWAY HD DISC BRAKES,DOUBLE ADJ.LADDER BARS, FACT.LOWER MNTS GONE. $1000.00 OBO
PLEASE CALLS ONLY 201-403-6333 BOB LOCATED IN NORTHEAST N.J. I PREFER PICKUP
racecarbob61 is offline   Reply With Quote
Old 02-12-2011, 12:14 PM   #2
monte442
Liked 3 Times in 1 Post
Default Re: hemi 4 spd, t-10 4 spd, glide,convertor/12 bolt
Is the Hemi box still available ? Can you send some pics and any other info you have for it to me @ mjmonte442@sbcglobal.net Where in New Jersey are you located ?
Thank you
monte442 is offline   Reply With Quote
