Old 01-29-2011, 02:05 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Cooling system question?
Do you run a thermostate, a restrictor washer or nothing in
your cooling system?
It's a mopar 26" wide 3 row radiator with a 383 motor 10 to
1 compression, 10 inch convertor.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 01-29-2011, 05:25 PM   #2
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default Re: Cooling system question?
I just have a washer in mine. it will get warm after 3rd run in a row, usually.
2894 STK
Old 01-30-2011, 03:12 PM   #3
Phillip marvetz
Phillip marvetz's Avatar
Restrictor with a moroso water pump drive.
2009 V/SA Record Holder
Old 01-30-2011, 03:34 PM   #4
jmcarter
jmcarter's Avatar
I've been running no restrictors with filled blocks low compression motors, you may have to experiment.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-30-2011, 06:29 PM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Jim has the definitive answer....(you may have to experiment)
Old 01-30-2011, 07:05 PM   #6
FED 387
Liked 333 Times in 180 Posts
just a restrictor definately no thermostat tho---
Old 01-30-2011, 08:34 PM   #7
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
Phill, The single biggest issue that I've seen in race cars, is no fan shroud. Most set-ups out there are either a water pump mounted fan with a Moroso drive motor, or an electric fan in a black plastic housing held on with plastic ties. Neither of which draws air thru the complete core. It's like you pulling two plug wires off before you go in the water box! Check your combination with this formula: measure the radiator core L x H = Sq. In. (example 20" x 18" = 360 Sq. In.). Now for the round fan, the formula is Diameter square x .7854 (exanple for a 16 inch fan: 16 x 16 x .7854 = 201 sq. In.). Now subtract the fan from the core (360 - 201 = 159). That means 159 square inches or 44% of your radiator has no fan drawing air thru the core. And you know what happens if you leave the fan off...it ain't pretty! but you're always leaving the fan off of 44% in this example!
The key is to move water as fast as you can, but you must be able to extract BTUs or heat from it while it passes thru the radiator. In order to do this, you must draw air thru ALL OF THE CORE and not just 44%.
Some folks say put washers in place of the thermostat to slow the water and hold it in the rad longer (to allow more cooling). But if you do that, where else are you holding the water?....the engine...and if it's there longer...it's getting hotter! Cool it better and run it thru faster! Ever wonder why the water pump companies make a pump rated @ 55 GPMs, it's not so you can put a washer with a 5/8s hole in the t-stat housing. Get the hot water out quicker....and the cool water in quicker! LOL
The use of a well made Shroud (sealing 100% of the rad core) and an electric fan combination will extract the maximum BTUs and provide your radiator to see it's full potential.
You would be suprised what that could do for your round-robin package!
Here's what I use
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
Old 01-30-2011, 10:44 PM   #8
Barry Polley
Guest
Posts: n/a
Here's what I use
Wade Mahaffey
I found that a restrictor in the lower hose holds the water in the radiator longer giving it a chance to cool further and of course a good fan and shroud are the ticket. I use a pvc pipe reducer inserted in the hose (5/8 ID) and clamp it into place.
Old 02-01-2011, 07:08 PM   #9
NewHemi
NewHemi's Avatar
We broke the center out of a thermostat and used the remaining ring as a restrictor.
It works fine, as long as we warm the car before our runs. Our car does like to run a when warmer so we have to make sure it gets up to temp.
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
