Old 01-29-2011, 12:40 PM   #1
et7333
et7333's Avatar
Default Sbc parts
BRAND NEW,not rebuilt,mini starter,3 h.p.,168 tooth,$185
IF YOU DON'T SEE WHAT YOU NEED HERE,I MIGHT BE ABLE TO GET IT,JUST LET ME KNOW WHAT YOU NEED.THANKS
8-JE NEW LOW TENSION 4.030X3/16 OIL RINGS ONLY- $25
Manley standard length super duty sbc valves,8-2.055,8-1.60 ground and ready to install. $130
GM 1.6 STAINLESS pro flow ex valves NEW $75
Jegs 1.6 ratio,7/16 full set roller rockers $85
Manley #22441 1.550 valve springs,brand new,$110
Moroso oil pan,#20211 used $75
MELLING M55HV billet gears oil pump NEW $40
Moroso oil pump pick up #24360 New $39
Several powerglide cores,make offer
Factory front drum brakes 68 camaro best offer
NEW Comp Stamped Steel 1.5 Ratio 3/8 Stud part#1212-16 $45
1.76 Hardened powerglide input shaft TURBO splines $60 USED
RJS 5 point Belts outdated $25
AFCO 90/10 shocks 67-69 Camaro $45 used
Prices do not include shippingContact Steve at et7333@netzero.net
http://stevecoxracing.com
et7333 is offline   Reply With Quote
