Liked 14 Times in 11 Posts
I need to purchase a decent tire pressure gage, something in the
30 to 60 lb range. Main purpose will be for tires and radial slicks. Anybody have a favorite brand that works correctly?
Phil Saran Parker, Colorado |
Hi Phil, I have had a moroso tire gauge for about 6 years with absolutely no problems. I received it as a birthday gift and have used it on my everyday cars. It has a built in bleed to make to make fine adjustments. Moroso now makes a few different ones and vary from about 38.00 to 145.00. Go to their site and see what best fits your need which probably be a 0-60 lb. Be sure to get the rubber protector for an extra 5.00 worth it if you drop it.----------John
Liked 99 Times in 60 Posts
Larry Woodfin 471W |
anywho, the above link may not work. Go the the Intercomp Gauges web site and look them over. You will see a wide range of options.
Liked 903 Times in 192 Posts
Moroso #89560
Bob Don 128 SS |
Liked 759 Times in 379 Posts
This is all I've ever used for 20 years
![]() I also don't check/adjust tire pressure between rounds and my cars are deadly consistent vary thousands in 60 feet from pass to pass. I've also been running radial slicks since 2000. ![]() ![]() Last edited by 1320racer; 01-27-2011 at 08:06 PM. |
Moroso 0-60 psi with rubber protector works great for me!
Shawn Blair 6383 SS 634 STK |
Liked 2 Times in 2 Posts
Moroso here also.
Nautilus Racing |
