a have a 12 bolt rearend was wondering what it came out of #3894860nf tube #bm 0213g2 A279 con1 can anyone help?
would you know if it was originally a posi unit. and i thought that the last number on the housing was the year?
Liked 333 Times in 180 Posts
BM is a 3:31 OPEN NOT a posi
could someone have changed the case because if i turn one side or the other both sides turn, even when i turn the pinion. inside it looks like on each side there is a plate w/springs. thanks for your help.Paul
The ORIGINAL rear end that came from GM was a 3:31 open gear---that is not to say that somewhere down the road it has not been changed to either a POSI or an entirely different ratio--- but as originally manufactured it was a 3:31 open ---sounds like ya got a posi in there whats the numbers on the gears???
the ring gear has #3093 419 usa y ? 1x on the case # ed3 30174 another # e 2 10
![]() Last edited by paulbass; 01-26-2011 at 09:44 PM. |
