Old 01-24-2011, 11:08 PM   #1
et7333
et7333's Avatar
Default disc brake pad drag
I just installed front Strange Disc brakes on my drum brake 68 Camaro.I was wondering if you guys put a spring on the pad mount bolt to assist in returning the pistons to eliminate pad drag?
http://stevecoxracing.com
et7333 is offline   Reply With Quote
Old 01-25-2011, 10:01 AM   #2
randy wilson
Liked 22 Times in 22 Posts
Default Re: disc brake pad drag
You sure can, Make sure nothing binds up.
don,t have one
Old 01-25-2011, 01:26 PM   #3
Mike Delahanty
Mike Delahanty's Avatar
Liked 276 Times in 54 Posts
If you do use a spring - you may be surprised the first time you get to the top end in competition and hit the brakes to close the gap only to find the pedal travel waaaayyy to long and braking not what you expected. Yep - happened to me - and yes I did breakout and give the race away. The springs got removed immediately.
