Old 01-24-2011, 12:59 AM   #1
59vette
Default Comp elim garage sale
Comp Eliminator Garage Sale
324 splayed valve complete less carbs..ran in B/TA mid deck block(new block) jenkins heads,dry sump motor. peterson,stef,jesel,meziere. Motor has low runs but have been sitting in a controlled air room. $12,000
324 splayed valve complete less carbs.. ran in B/TA mid deck block, lump cylinder heads,dry sump motor. moroso,stef,jesel,T&D. Motor has low runs but has been sitting in a controlled air room. $12,000
Will make a package deal for both!
3.250 Bryant crank(used) 283 main/1.888 1337bw $1,200
3.220 Crower crank(used) 283 main/2.000 $1,200
davinci dominators 2.000 (old style bodies) pr. $1,750
Brashear dominators 2.000 BG demons pr. $1,750
9" R&P 5.57 pro gear(used) $125
9" R&P 6.20 pro gear lightened(used) $125
9" R&P 6.33 pro gear lightened Dewco(new) $500
3- 55mm roller brg splayed lsm cams- mid deck $150 ea.
1- 55mm roller brg splayed cam motion- short deck $150
3- 60mm splayed lsm cams- short deck $150 ea.
7" ati balancer(used) has brand new hub $150
.937 keyed jesel lifters(used) .785 wheel/offset-8pcs $400
psi valve springs DR1250 14 pcs-new $150
2 msd hvc coils(used) 8261 $75 ea.
msd hvc coil (used) 8251 $50
msd coil(used) old style red coil $20
Barry Grant 4 port regulator(new) 170023 $125
msd 7551 launch rev controller for 7530 box(new) $75
msd 7559 programmable shift controller(new) $200
2 csi trans shields- pro trans(used) no hardware $75 ea.
precision shifter 3 sp. protrans. with air cyl./
shift cable and pan brkt.(used) $250
A-1 7" convertors $600 ea.
B325-4
A300-10
AE++300-8
AE300-3
Mark williams center sections 40 spl.(used) $1,500 ea.
5.83
2-6.00
6.20
Scott Benham
comp4254@netscape.net
cell 281-380-2864
shop 281-252-7223
59vette is offline   Reply With Quote
