Old 01-21-2011, 12:59 PM   #1
FINESPLINE
FINESPLINE's Avatar
Default Stocker flat tappet lifters
Considering the aggresive grinds that are now used in stock, what lifters would be recommended ( solid & hydraulic ) in a chevy. I have read up on the Schubek---Smith Machine style and some tool steel type. Also , what varieties of treatments can be used on the camshaft itself. What experiences can you pass on ? Thanks in advance, John
FINESPLINE is offline   Reply With Quote
Old 01-21-2011, 02:27 PM   #2
Default Re: Stocker flat tappet lifters
The most reliable is the tool steel, because, simply put, they don't break, where any ceramic lifter can break, or even shatter. If you're going to run a cast iron core cam, DO NOT use coated lifters. If you're going to run a steel billet cam, then you can run coated lifters. The cam needs to be fully de-burred, and if possible, nitrided.
Old 01-21-2011, 02:42 PM   #3
BlueOval Ralph
Banned
If you run tool stell with DLC DO NOT ANY LUBE WITH MOLLY as th Mooly itneracts with DLC
BlueOval Ralph is offline   Reply With Quote
Old 01-23-2011, 10:10 PM   #4
Rick Leininger Jr.
On a serious stocker effort I would go with a DLC lightweight steel lifter on a polished billet or powdered metal oversized cam core.
Rick Leininger Jr. is offline   Reply With Quote
