Old 01-18-2011, 11:08 AM   #1
Bobby Zlatkin
Bobby Zlatkin's Avatar
Question Extended length ball joint stud
I know this has been on here before, but I can't find it.
Couldn't find it in their catalog, so I called AFCO. They have a low friction, but not an extended length stud ball joint for a '67-'69 Camaro.
Who does? Part #?
Thanks,
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 01-18-2011, 11:33 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Extended length ball joint stud
afco 20034-1 & 20038-1 upper and lowers
Old 01-18-2011, 11:47 AM   #3
Bobby Zlatkin
Are you sure FED387? AFCO lists #20034-1 as a screw-in ball joint for a Ford Pinto.
Old 01-18-2011, 11:58 AM   #4
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Sent Link, in PM
Bob Pagano A/SA
Bob Pagano is online now   Reply With Quote
Old 01-18-2011, 12:37 PM   #5
Alan Warman
Last time I talked to Afco they only had them for the G-Body's. Howe has them for everything you can think of. But everybody tells me if you use the Howe ball joints, your car will turn left at the end of the track.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 01-18-2011, 08:44 PM   #6
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
qa1 makes them . heres the link http://qa1.thomasnet.com/viewitems/b...001448|3001453
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 01-18-2011, 09:58 PM   #7
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
LMAO @ Alan !!!!
2894 STK
Old 01-18-2011, 11:15 PM   #8
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Coleman Racing Products has what you are looking for...
http://www.colemanracing.com/Ball-Jo...ize-P4401.aspx
Old 01-29-2011, 10:28 PM   #9
blasttime
blasttime's Avatar
I believe you will be much happier with the quality of their products www.howeracing .com The studs come in 5 lengths and rebuidable. Use locktite on set screws assemble with oil.
blasttime is offline   Reply With Quote
