Old 01-18-2011, 05:41 AM   #1
Rick Leininger Jr.
Default Comp, SS, Stocker parts - make offers
Some GM, Ford, Mopar new & used pieces from ex projects, make offers on this stuff, it all needs to go!
Never run LS1 NHRA Stocker heads by Tim Sloan, complete, ready to bolt on 241 center bolt castings with valves, PAC-1409 springs, 7 gram steel retainers, Comp machined locks. Changing classes reason for sale - $1500 shipped
Flow info, cfm @ 28" - int/exh
.100" - 68/54
.200" - 146/101
.300" - 204/139
.400" - 236/168
.500" - 248/183
.550" - 251/190
LS1 NHRA Stocker pistons, JE #295643 recently approved, 3.965" bore 1.313" CD, .0635" x .0635" x 3mm ring grooves for use with .8mm x .135" Total Seal gas ported spacer package, or backcut 1/16" rings, Calico CT-3 skirt coating, weigh 395 grams. Precision Products .927" DLC coated 9310 pins for the above pistons, weigh 119 grams, dyno time only, changing classes reason for sale - $850 shipped
Custom aluminum LSX box straight side oil pan by Tim Sloan. 8" depth front, 9" depth rear. includes removeable one way screen and oil pump pickup - $400 shipped
Schoenfeld LS1 1-5/8"-1-3/4" stepped dyno headers, with collectors and O2bungs - $350 shipped
New JE 866-2000-15-64C wrist pins, GKH steel (same material used in Pro Stock & NASCAR crankshafts), DLC coated, ultra finish I.D., 87 grams, chamfered for wire locks - $300 shipped
New JE 866-2000-17-74C wrist pins, 300M steel, DLC coated, ultra finish I.D., 97 grams, chamfered for wire locks - $200 shipped
Mopar BDR P7 NASCAR plate intake with insert - $125 shipped
New Ishihara-Johnson crank scraper for 383-440 Mopar - $40 shipped
Paypal accepted, PM for pics if needed, all shipping paid to continental US addresses
Rick Leininger Jr. is offline   Reply With Quote
Old 01-18-2011, 01:53 PM   #2
Paul Wong
Liked 419 Times in 85 Posts
Default Re: Comp, SS, Stocker parts - make offers
how can you be contacted?
Paul Wong is offline   Reply With Quote
Old 01-19-2011, 07:54 AM   #3
Rick Leininger Jr.
I'll send you a message with my info.
