Old 01-17-2011, 05:26 PM   #1
Glenn Betz
Default Super Stock Sale!!!! Getting out of Racing
2005 Pontiac Sunfire Super Stock/GT car. The car has a Strange 9inch Ford rear end. Strange aluminum center section with 5.67 gear and Strange axles and brakes. Full chrome-moly tubing chassis 4-link. Strange struts and brakes. It has Mickey Thompson wheels and front tires, Hoosier Radials tires on the rear. ATI Powerglide with ATI converter. The transmission has just been freshened up and the converter was new in June 2010 with about 30 runs on it. MSD 7-AL3 ingnition box with MSD coil. The engine is a 350 small block 300hp. With this motor the car will run AA and BA. Car get down to 2710# with 160lbs driver. Also, 350 small block 255hp engine. Has about 20 runs on the engine. In GT/CA in Chicago 2010, went 9.79 at 134mph. Also, a spare converter, two spare cams, and a bowite block already machined with .904 big lifter bores and 55mm roller bearing cam tunnel and lightened. Getting out of racing. Make offer!!!!!!
Call Glenn Betz at (812-342-9408)
Glenn Betz is offline   Reply With Quote
