Old 01-10-2011, 01:42 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Question Master Cylinder Mounting Plate and Brake Rod
I am in the process of replacing the stock power brake booster and master cylinder on my 77 Camaro with a Wilwood aluminum piece. The issue I have come across is that Wilwood does not make (that I can find) an adapter plate to go from the 4 bolt vac booster mouting bolts to the 2 bolt master cylinder. Also, I need to find a brake rod that will work with the stock pedal but insert into the new master cylinder correctly. I would like to find a rod with some sort of retention feature that will stay captured in place to avoid the rod dropping like I have heard of some fellow racers having issues with in the past.
Any help locating a mounting adapter and brake rod recommendations will be appreciated.
Thanks,
Chad
Chad E532 is offline   Reply With Quote
