Old 01-10-2011, 09:37 AM   #1
jethro
Default Comp and super stock parts clean out
1. A1 7'" converter AE300-8 $1000-
1. BBC Jesel belt drive (missing cam hub) $450-
1. SBC Jesel belt drive (cover only) $50-
16. PAK ***. retainers 1.500 dual springs $200-
8.PPC 2.250 x.927 coated wrist pins $350-
6. ***. coated wrist pins .927x 2.500 $300-
6. Jesel splayed valve intake rockers DA2D75 $300-
16. PAK 1355 springs $100-
8. Crower.842 roller lifters 15* $50-
16. Xceldyne super 7* ***. retainers and 5/16 ***. locks $250-
2. Magna fuel 4150 shear plates $50- each
8. Jesel 15* exhaust rockers DHEL65 $400-
8. Jesel 15* rockers CJBL70 & CUGR70 w/ shafts $800-
1. 9" ford iron case with 3.250 bearing $200-
9. CP pistons 4.150x1.375 blob domes $400
1. Penske shocks reg. and air release valve (test only) $275-
1. set GOODYEAR 1999 98" roll out, 30 runs $100
MISC. 50 & 55 MM cams $150-$300 (CALL)
JESEL push rods
8. dbl. taper .400 to .440 x 9.040 ball end
8. dbl. taper .500 to .560 x 9.020 ball end
16. dbl. taper .400 to 440 x 9.120 ball end
MANTON push rods
8. single taper .380 to .440 x 8.870 cup end
8. single taper .380 to .440 X 9.050 ball end
ALL PUSH RODS $20 EACH
ALL PRICES ARE WORKABLE CALL JOE CARNASCIALE FOR MORE INFO...
401 447 4650
401 943 6029
jethro is offline   Reply With Quote
