Old 01-05-2011, 12:10 PM   #1
John H186
Default 302 Ford engine and Mustang parts
Ford 351 Windsor heads.
Part number DOOE and 351 on bottom of them.
1.94 / 1.50 valves with single springs with dampers.
Manley screw in studs with guideplates.
Port matched but not a full port (race) job.
1.6 Ford Racing (blue) roller rockers.
Hardened black pushrods (I think Manley as well).
Stock head bolts.
$400 takes everything.
RCI black plastic 10 gallon fuel cell with straps and foam. $80.
Moroso 4 inch face mechanical tire pressure gauge. Make offer.
1-inch open plastic carb spacer for 4150 carb bolt pattern. $10.
Jesel Pro Series Mohawk shaft rockers for most inline Ford heads, GT-40, AFR, etc.
Codes on bottom are BAAS60.
1.60 int / exh. Mohawk lightening slot, roller tips, tool steel adjusters, fully optioned. (These are still in the plastic sealed package and have never even seen an engine). Straight, no offsets. I don't have the steel stands, just the eight rocker pairs on shafts. Brand new, Make offer.
Call John at 732/910-2145.
Thank you for looking.
John Hedenburg H186
John H186 is offline   Reply With Quote
