Old 01-03-2011, 10:50 PM   #1
Doug Domm
Liked 85 Times in 22 Posts
Default What do YOU use to keep rust off stored parts?
I need to move some blocks, heads, and misc. other parts to cold storage. This is VERY COLD storage as in Saskatchewan winters. What works best for you? I once had some spray stuff that had a reddish color to it that worked very well, I applied it probably more than 10 years ago and those blocks still look like the day it was applied. For the life of me I can't recall what this stuff was. Must be that old timers syndrome. Doug Domm
Doug Domm is offline   Reply With Quote
Old 01-03-2011, 11:43 PM   #2
Kegracing
Default Re: What do YOU use to keep rust off stored parts?
Doug,
Not sure exactly what you are looking for... as for grease, I have found that motorcycle chain lube works very well. Is made to cling, and not sling off... this keeps if from running and dripping off as bad. Comes in aerosol cans... spray it on, and wipe on as needed, wrap and store.
If you are looking more to a paint, then Glyptol (spelling?) paint works great. It is usually a dark red - primer red color. Used in the electric motor field. Lots of people use it to paint the inside of blocks, etc.
Good luck,
Ken
Kegracing is offline   Reply With Quote
Old 01-04-2011, 12:38 AM   #3
Doug Domm
I'm thinking more in the way of an oil or grease product to protect machined surfaces that can be washed off later so the blocks and heads can be painted after assembly.
Old 01-04-2011, 01:47 AM   #4
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Doug, I know what you are talking about, but can't think of the name. I've seen people spray it on bumpers and aluminum wheels during the winter. I will find out what it is.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 01-04-2011, 06:27 AM   #5
cad
cad's Avatar
Liked 93 Times in 52 Posts
Is it Cosmoline you're after?
http://www.cosmolinedirect.com/?gcli...FQxl7AodZ04WpQ
Old 01-04-2011, 06:43 AM   #6
Phil Veldheer Racing
Liked 26 Times in 8 Posts
Thumbs up Re: What do YOU use to keep rust off stored parts?
http://www.moldmoreparts.com/A677txt.htm
I recommend and use this product,
Phil
PHIL VELDHEER 3455 STK
IHRA WORLD Record Holder
2007-08-09-10-11-12-13-14-15-16
Phil Veldheer Racing is offline   Reply With Quote
Old 01-04-2011, 10:03 AM   #7
Jim Kaekel
Liked 540 Times in 112 Posts
Valco Gel Lube works well also.
http://www.valco-cp.com/GelLube.htm
Jim Kaekel 3836 STK
Old 01-04-2011, 10:36 AM   #8
Greg Barsamian
Liked 427 Times in 97 Posts
We used to use a product called "Ruslick" however our lubricant supplier discontinued it due to it's contents.
We now use a product called "Anticort" SV95 X 5 gallon pail.
by Fuchs Lubricants
17050 Lathrop Ave
Harvey ILL 60426 USA
(708) 333-8900
www.Fuchs.com
Old 01-04-2011, 12:51 PM   #9
Joe Martens
Yes, cosmoline is what I was thinking of.
