Old 12-30-2010, 11:32 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 Z28 Intake and 1966-69 BBC HiPo Parts
1969 Z28 factory aluminum intake with heat shield intact $450
1966 3873858 heads F-13-6 & F-17-6 $1750
1966 3873858 heads D-18-6 & E-2-6 $2500 rebuilt
1967 3904351 427 4 bolt standard bore block H-18-6 $6000
1967 3904391 heads J-10-6 $3000
1968 3919840 heads F-17-8 & F-18-8 $1500 rebuilt
1968 3935440 396 4 bolt block with MQ code E-21-8 $1250
1968 3935440 396 4 bolt block with CE code F-10-8 $1500
1969 3919840 heads J-31-8 $1250
1969 3919840 heads L-3-8 & L-4-8 $1250
1969 3919840 heads A-22-9 $1750 rebuilt
1969 3955272 396 4 bolt L89 KG coded block J-14-8 $3000
1969 3955272 396 4 bolt L89 JJ coded block J-7-8 $3000
1969 3919840 heads C-25-9 $1250
Can ship as well if you cannot pick it up. 330-770-2517
dlv4540 is offline   Reply With Quote
Old 12-31-2010, 01:29 AM   #2
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: 1969 Z28 Intake and 1966-69 BBC HiPo Parts
WHERE are you located. Jim Hanig
Old 12-31-2010, 03:19 AM   #3
Tom Moock
Liked 10 Times in 6 Posts
Jim, 330 area code is Ohio, Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 12-31-2010, 10:46 AM   #4
dlv4540
I live in Warren Ohio about an hour east of Cleveland.
