Liked 708 Times in 285 Posts
1) used bbc jesel belt assembly standard cam location. Cover, crank gear, cam gear, with new camshaft seal, used belt. (missing camshaft hub and bolt and should have crank seal replaced before install). I guess camshaft hub went into garbage when cam was thrown away. $375.00 shipped to lower 48 states
2) new sbc jesel belt only #25mm 208mc and camshaft seal # sel-37200 for stock location camshaft $95. For both shipped to lower 48 3) bbc arp head bolts (not studs) new in box 135-3601 (missing 2 bolts) $40 shipped to lower 48 states 4) moroso style electric water pump. Motor is good, both pulleys universal adjusting bracket and bolts. (missing belt) $25.00 shipped to lower 48 states. 5) bbc 290 oval port heads. Closed chamber peanut spark plug. Purchased for spare set for my 454/390 combo and never had them checked but removed from motor after it was pulled from wreck. I dont have date numbers but will get if needed. I paid $200.00 and pulled them off myself . $200 plus freight is all i want back from them i will send pics of anything your interested in. Jeff Stout 602-768-3583 AZ Last edited by Jeff Stout; 12-16-2010 at 07:35 PM. Reason: number |
Liked 2 Times in 2 Posts
PM sent.
