Old 11-28-2010, 12:17 AM   #1
rampage340
Default 340 Parts
1 71 340 std bore block 250.00 3 std steel cranks 75.00 Eh1 cast crank 25.00 1 stock center sump oil pan with 2 pick-ups and oil pump 50.00 1 68-69 timing cover50.00 1 70-73 timing cover30.00 1 set .060 340 speed pro 13:1 pistons cam fly cut to what you want 225.00 5 set 340 floating rods 40.00 Eh 4 340 steel crank dampers and bolts 20.00 Eh 1mini starter 75.00 1 roller timing chain 20.00 1 DC gold ign box 75.00 2 cam plates 5.00 Eh 1 flex plate 10.00 1 set 8 3/4 axle bearings 50.00 2 T/A manual valve bodys 125.00 Eh
Thanks Kevin 727-743-1307 9:00AM to 10:00PM EST
rampage340 is offline   Reply With Quote
