Old 11-26-2010, 02:13 PM   #1
HIGHOCTAIN2000
Default piston rings
can a .043 ring be used in place of a 1/16 in super stock . can't find any thing about rings in the rule book in super stock.
HIGHOCTAIN2000 is offline   Reply With Quote
Old 11-26-2010, 02:24 PM   #2
340Cuda
Liked 805 Times in 341 Posts
Default Re: piston rings
Since rings are not mentioned in the SuperStock section I think the Stock section is where you need to look.
PISTONS
.....Piston may not be remachined for special rings.....
Old 11-26-2010, 02:56 PM   #3
art leong
I know you can use aftermarket pistons, so you can use any rings you want.
I'm not sure about gas ports though.
Art Leong 2095 SS
Old 11-26-2010, 03:20 PM   #4
Jeff Lee
Jeff Lee's Avatar
vertical gas ports are not allowed (doesn't look factory) and you can use any kind of ring, in any location and and number as you wish in Superstock.
Jeff Lee 7494 D/S '70 AMX
