Old 11-13-2010, 06:27 PM   #1
JeffM
Liked 5 Times in 5 Posts
Default Garage sale
NOS in original package Moroso Master Disconnect switch pn74101 - $30.00
NOS - Jesel replacement belt .391 raised cam pn31052 - $80.00
New open box never used ARP early LS stud kit pn234-4316 – $300
New in sealed box ARP late LS Stud kit pn234-4317 - $250
New ATI crank pinning kit pn918993 - $75.00
New Comp BBC cam button pn207 -make offer
New Comp Cams poly locks 7/16 - 2 sets –$25.00 per set
2005 LS2 low mile take out camshaft – make offer
New Comp Cams light weight fuel pump push rod pn 4616 - make offer
New Comp Cams rocker studs – 302 Ford 3/8 x 5/16 pn4504-16 –$40
Edelbrock SBC Victor Jr. Intake pn 2975 – never ported used but nice shape - $125
Impact racing cam lock 5 pt safety harness with mounts Manf June of 2009 pn58741111 pullup lap - $50
Comp Cams LS1 retrofit lifters new in box pn15956-16 $450.00
Set of 8 take off L92/LS3 intake rocker arms pn12569167 less than 3000 miles in great condition $75.00
Set of 8 LS1/LS6 injectors GMpn12561462 – Bosch pn0280155931 (28.8@58psi) - $100.00
Comp cams SBC hydraulic flat tappet cam – ran for approximately 1000 miles in great condition $50.00
12-213-3/ 244/244 .501/.501 110 - CS 292H-10
Pair of 041x heads - Cleaned, magged and pressure tested bare stock - $450.00
Pair of 461x heads – Cleaned, magged and pressure tested bare stock - $600.00
NOS Rod bearings in original packaging - $20.00 per set of 8
CB663P – 2 sets of 8
CB663P-1 – 2 sets of 8
CB663P-20 – 1 set of 8
CB743P-1 – 2 sets of 8
CB743P-10 – 1 set of 8
CB745H – 1 set of 8
CB745P – 2 sets of 8
CB745P-10 – 1 set of 8
CB745P-30 – 1 set of 8
NOS Main Bearings in original packaging
MS429H – 2 sets - $50 per set
MS429P-20 – 2 sets - $50 per set
MS429P-20 coated – 1 set - $100
MS829P-30 – 1 set - $50
NOS piston rings in original packaging
R20109-5 - 4.125 in. Bore, 0.043 in., 0.043 in., 3.0mm $125.00
R20109-65 - 4.180 in. Bore, 0.043 in., 0.043 in., 3.0mm $125.00
R20100-65 - 4.060 in. Bore, 0.043 in., 0.043 in., 3.0mm $125.00
R20101-5 - 4.000+5 in. Bore, 0.043 in., 0.043 in., 3/16 $125.00
E377X - 4.000 in. Bore, 5/64 in., 5/64 in., 3/16 in. $20.00
Buyer pays all shipping costs – pictures available upon request
Contact Jeff at superstock@live.com or 260-223-0157
JeffM is offline   Reply With Quote
